Is Softscrub enough for the top deck or wax it too?
craiglaforce
Re: Is Softscrub enough for the top deck or wax it too?
Post by craiglaforce »
If you want a non-slip wax, try a surf shop. If nothing else, it gives you a chance to hang out and act cool.
Those guys wax their boards all the time and then stand on them while going 40 mph down waves.
Dr. Zog's sex wax if I recall. I think they had a bunch of different tackiness wax types.
http://www.sexwaxdealer.com/index.cfm?f ... egory_ID=1
SkiDeep2001
Post by SkiDeep2001 »
craiglaforce wrote:If you want a non-slip wax, try a surf shop. If nothing else, it gives you a chance to hang out and act cool.
Way to go Craig, now all these guys are going to be scrambling to find their receipts so they can return the stuff they already bought :!: :P :wink: 8) Rob
craiglaforce
Just trying to do my patriotic part to stimulate the economy.
Andy26M
Post by Andy26M »
Surfboard wax is more like candle wax than car wax - it is sticky and after every few applications needs to be removed (it gets thick and can ball up). It also collects dirt like nobody's business - and the dirt is stuck in there until you remove the wax. As stated above, the purpose is to provide a sticky, non-slip surface to surf on - NOT to make things look all spiffy and shiny.
I'd never use surfboard wax on my Mac topsides.
- Andy
Gazmn
Post by Gazmn »
Ditto... Dude :P ...
craiglaforce
yes, I watched a youtube of the zog man waxing a board and it was all white clumpy gunky looking.
http://www.youtube.com/watch?v=tLLURPcy0VE
Duuude.
Man, sailing is really getting cooooooool. We got dudes :!: 8)
craiglaforce
http://www.youtube.com/watch?v=MGGymUhU ... re=related
Some people hide from hurricanes, other people do this. Man I feel old.
SkiDeep2001
Removed and edited below.
SkiDeep2001
While on the deck subject, can I use my Briggs&Stratton 2100 PSI pressure washer on the boat or will it do some damage :?: 8) Rob
SkiDeep2001
craiglaforce wrote:yes, I watched a youtube of the zog man waxing a board and it was all white clumpy gunky looking.
I ski and snowboard and use a heat gun when waxing my boards. I wonder if that would help lay that surf wax down so it had a nice finish and gave you sure footing on a wet deck :?: 8) Rob
SkiDeep2001 wrote:While on the deck subject, can I use my Briggs&Stratton 2100 PSI pressure washer on the boat or will it do some damage :?: 8) Rob
Not in fast passes, but never focus a pressure washer on fiberglass for any length of time as it has the potential to damage the gel or even the underlayment.
SkiDeep2001
Thanks Kevin, I've seen a pressure washer peel wood and pit asphalt so yes I would open nozzle, just wanted reassurance deck is done well enough to stand a fanned pass. 8) Rob
SkiDeep2001
Dang, I should check my links, here's a Re-Post of my Re-Post by SkiDeep2001 » Tue Jul 14, 2009 7:23 pm
And some do THIS :!http://www.youtube.com/watch?v=4UCQFJg4JaQ:( Rob - On edit - Sorry about that, this is the one I meant to post. Didn't mean to make fun of someone who probably suffered serious injury. :( http://www.youtube.com/watch?v=RU6Wtqd6 ... L&index=18 :o :P :P :P :wink: :wink: :wink: 8) Rob
SkiDeep2001
Fixed link in post above :x 8) Rob PS - First link is blacked out intentionally. If you're curious It shows the kite surfer who got blown across the highway and into the side of a building while surfing high winds.
