I am guessing about 30'.
I will be installing a new topping lift. Tied off to mast head with some adjustment capability at the boom end.
Those clips are also good for attaching the topping lift to the safety lines so the topping lift doesn't wind up at the top of the mast - - - like it did every time I handed it to The Admiral to "hold onto this for a minute honey" - - - I guess she took me seriously, because after a minute, it was again at the top of the mastAlaskaMan wrote:I used 30ft of 1/4 inch dacron line and put two clips about 2 feet apart on the boom end. I can raise the boom above my head level when I dont have the sail out or lower it when I put up the sail.
I used good ole' Mr. Pythagorus for the 30'. Boom = 10', Mast (from gooseneck to top) = ~28' = 100 (10 squared) + 784 (28 squared) = 884 = 29.732 (square root of 884).Kelly Hanson East wrote:30 feet sounds way too short?? The mast is about 30', and you have to run the lift back down the mast of course...you might also consider buying more in case you want to run it aft....
