I guess in a perfect world, you might have a more dynamic adjustment of mast rake like some of these racing boats have (pretty hard with a furler though - and aft attached shrouds). But still, are you going to have to adjust it on each point of sail as well as the changing wind conditions? The other thing that is confusing about the windsurfing analogy is that you have to rake your mast back more in increasing winds for reaches as well as upwind beats. This also causes the board to lift up and adds speed because of that.
Then of course, Craig joins in and describes pretty much what I have done too...tightened the turnbuckle up all the way on the stock forestay. But I used to have my shrouds tighter and that caused more rake. Now that I think that my shrouds are too loose again, its made me think about shortening the forestay...again.
I guess I'll try the boat pitch experiment I mentioned above and then report back. I suppose another possibility is having two different length forestays. But I'd rather find one good tune and stick with it...too much of a hassle to always be changing it around IMO. (pragmatical sailor approach again)
Thanks for all the replies, its an interesting (and controversial) discussion.
