I thought I would post a new thread and not muddy up the 'solar panel' one so much.RussMT wrote:.........WiFi is growing everywhere and I've experimented with directional antennas. I'm interested in your WiFi solutions here. For me, WiFi just won't cut it and I've found an app that lets me connect my G3 Droid phone to my notebook. It seems to work well and I'm hoping to get service with it....--Russ
We would like to have access to WiFi wherever/whenever possible. With the laptop we were able to pick it up at one location in Canada on Kootenay, but it was iffy and as the boat swung on anchor I would loose it. There we must of been about 300-400 yards from the nearest place that had an unsecured server.
There has been some really good discussion over on www.cruisersforum.com...
The following link is the best, but also by far the longest and takes more than a night to read through...
Long-Distance WiFi Device
This one is shorter, but also not near the info as the first one.
A Simple, Inexpensive WiFi System that Works
The next answered questions I had about the Bullet 2 HP radio that actually receives and sends to the remote server.
Bullet 2 HP
For 90% of the people out there that want long distance WiFi I would just order a system from......
Island Time PC
....I'll be able to build one for about $50 less, but his comes ready to go and you can get going on it without knowing much about computers, routers, antennas and radios. He also builds 12 volt computers similar to what I'll be doing.
I was about ready to buy one of the USB long range solutions, but after wading through all of those links feel the the Bullet 2 HP mounted on the antenna with no coax is the best solution. You don't loose all of the signal strength that you do with longer runs with coax as from the Bullet (the radio transceiver) to the computer or in our case to a wireless router you use an outdoor Ethernet cable.
Once again the reason we are doing this is mainly to try and stay in touch with the kids and friends on our long trips. I'd also like to put my trip log up while underway. The cost to do this is about $225.
I've looked into some of the phone plans, but have a hard time wading through them and then finding a carrier that might work in all the places we will be going to has been confusing.
As far as antennas go it seems that most people who have built a lot of these settle on an 8 dBi omni antenna. It is hard to get a directional to work when you are swinging on anchor. Above 8 dBi if you are in close to a marina or some other place that has a WiFi server antenna mounted high you have a good chance of missing the signal as the vertical height angle that you receive at becomes so small that you will be trying to receive under their signal. The above links can explain it better. Also as the boat rolls side to side you can miss the signal with a higher gain antenna for the same reason as you really narrow down the effective window height wise that the antenna is sending and receiving at.
I use to just think about receiving WiFi signals but we have to remember it is a two way street and if you can't broadcast back to the server from your end you won't have a connection either. There again with the radio (bullet) right at the antenna you put out a much better signal that if the radio is on a card in your computer and you are sending the signal to the antenna via a coax cable.
An interesting subject and I'd like to hear what works for any of you guys,
Sum
Our Trips to ...
Our Mac Pages
Mac Links
