As was mentioned, the passive ballast vent to the prow, clear vent hose goes up at the very front of the V-berth, only visible for a few inches, then straight up into a u-turn made up of glued angles, so the loop can't collapse, at the very top right under the deck in front of the anchor locker, and then back down to next to the anchor locker drain, where there is a T fitting that joins the anchor drain to the ballast vent.
All turns were done with solid angle fittings, threaded nipples, and glued joints to make secure whenever possible, and avoid bends in the vent hose that migh otherwise collapse. Wherever the clear vent hose is attached to the PVC pipe fittings, use stainless steel hose clamps. It also makes it easier to put the top of the "loop" right up against the deck, without actually having to reach all the way up there, by pre-assembling the two hoses and U-turn fitting.
Even if the anchor locker drain gets plugged completely at the exit hole in the hull, the water will fill the locker and overflow off the deck before it can get up as high as the upside-down P-trap of the ballast vent hose at its highest point under the deck at the very nose of the boat.
At the vent cup over the tank, I drilled a second hole next to the original one, the same size, so it can be plugged if ever needed like the original hole, with a regular plug. In that new hole, a rigid plastic nipple leading into a ball valve, and then a solid right angle fitting,to aim the hose across the top of the flotation under the V-berth. The ball valve and fittings there are also retained by a cross member at the top of the vent cup (the dam), so not to just rely on glue or the fit to keep it in. The ball valve is an added measure, not difficult to install, that allows the closure of the passive vent if extremely rough weather is coming, and it leaving the boat at anchor, or slipped for several days etc.
By leaving the original hole, with the original plug in it, you can still visually check the tank anytime, but for most of the time, the vented tank will take care of itself. However, when first coming back to the boat, after being in the water for awhile, it is easy to check the ballast to ensure it is dry, or filled all the way.
In all I drilled 3 holes in the he boat; the tank next to the original vent inside the dam, in the forward lower bulkhead above the ballast vent but below the liner, and in the liner at the very front of the V-berth, for the ballast vent hose. Except for the few inches at the nose of the V-berth ,the rest of the vent hose is totally not visible in the boat, except by looking into the storage access areas, or up at the nose in the V-berth in front of the anchor locker.
Three years now since the mod, and no problems, no problems anticipated.
If you have guests below, no need to move them around to check and open or close the vent, the several times usually, and it is WAY better if single-handing to not have to leave the helm to deal with the vent.
