My 2 cents: The Mercury is lightest and seems to be a good deal, as long as the engine is not a reliabilty problem, ask why is this nearly new motor once again looking for a boat to live on? If you mostly want to sail, and powering is secondary, I think the Mercury is the one to choose. If you are going to pull skis or innertubes or want to go fast then don't shop for less than 90 hp. The Mac26 is like a houseboat to a 50hp outboard, so to operate it like a decently able powerboat requires much more hp.
Tohatsu TLDI 70 hp Spec 2.3:1 gear ratio 315 lbs.
Outboard salesperson wants you to buy this one lowering the price
http://www.tohatsu.com/outboards/70tldi_spec.html
Mercury Bigfoot 60 hp fuel inj, 2.33:1 gear ratio 264 lbs.
Great price for this slightly used motor
http://www.mercurymarine.com/mercury_60 ... fourstroke
Just for comparison, since you have some time to ponder this decision, a few more outboards to consider:
The ETEC 90 hp Salt Water 2.25:1 gear ration 326 lbs.
No maintenance for 3 seasons will save $$$$
http://www.evinrude.com/en-US/E-Tec/200 ... IN-LINE.3/
Tohatsu TLDI 90 hp Spec 2.0:1 gear ratio 315 lbs.
For the same weight as the TLDI 70, 20 more hp.
Suzuki 140 hp, 2.38:1 gear ratio, 410 lbs.
Best power to weight ratio, excellent gear ratio, and Billy likes his.
http://www.suzukimarine.com/sr05/df140/ ... _specs.php
Pound for pound:
4.4 lb. / hp = Mercury Bigfoot 264 lbs / 60 hp
4.5 lb. / hp = Tohatsu 70 hp 315 lb. / 70 hp
3.5 lb. / hp = Tohatsu 90 hp 315 lb. / 90 hp
3.6 lb. / hp = Evenrude Etec 90 hp 326 lb. / 90 hp
2.9 lb. / hp = Suzuki 140 hp 410 lb. / 140 hp
If I had to pick one of these for my use, I'd have a tough decision between the Suzuki 140, for its quiet and with my really nice Suzuki dealer relationship, or the Evenrude ETEC 90 for the freedom from maintenance for 3 years (save $200 to $400 per year plus the time to take it in), plus I like new technology. Since it is a "first year new product" situation for the ETEC, in 2005 I'd go with the proven Suzuki 140. Of course the extra hp helps out that decision. But the ETEC low maintenance, if it turns out to really be reliable, will be the lowest cost of ownership.
