Picked the wrong day to put the mast up
... think tomorrow I'll pound a metal stake in the ground and hook some old jumper cables up to it to ground it until I take the mast down...
http://familywoodworking.org/forums/att ... 1282430670 by KingBubbaTruck
Sat Aug 21, 2010 6:59 pm
Forum: MacGregor Powersailor Discussion
Topic: Picked the wrong day to put the mast up
Views: 3 Jump to post
Re: Lightning
Just to make one thing clear. If I do install a grounding system it WON'T BE JUMPER CABLES ATTACHED TO A METAL PLATE. It would be in accordance with the following....
http://www.kp44.org/LightningProtection ... ndards.php
I'll leave the jumper cables in the Suburban,
Sumby Sumner
Fri Jun 04, 2010 10:45 pm
Forum: MacGregor/Venture Discussion
Topic: Lightning
Views: 1174 Jump to post
Re: Lightning
... have a false sense of security. The same false security of believing jumper cables over the side will work. A few years ago I was motoring back from the northern most ...by NiceAft
Fri Jun 04, 2010 3:59 pm
Topic: Lightning
Re: Lightning
... on about poorly grounding. Hanging an inadequate ground over the side (jumper cables) will provide a path that will result in molten jumper cables melting a hole in the ...by RussMT
Fri Jun 04, 2010 3:06 pm
Topic: Lightning
Re: Lightning
I've heard of people who attach one end of jumper cables to their shrouds and throw the other end overboard.by mgmathews
Thu Jun 03, 2010 1:33 pm
Topic: Lightning
Re: Laptop computers
I have an 800amp booster jump pack it will charge from the batt. jumper cables I am sure but would have to check it also charges from the 110vlot inlet or 12vdc outlet ...by Highlander
Wed Mar 10, 2010 6:37 pm
Forum: Repairs and Modifications
Topic: Laptop computers
Views: 627 Jump to post
Any idea is the battery pack can be charged by attaching the jumper cables to a house battery when the panels are working?
No this wont work. Almost all the modern jumper packs are diode protected. You probably do have a 12 VDC connector which can be used for charging though.by Kelly Hanson East
Wed Mar 10, 2010 1:45 pm
... we won't be freezing with it. I was thinking of carrying a 12v battery jumper pack,as a backup. Any idea is the battery pack can be charged by attaching the jumper cables to a house battery when the panels are working? Most packs come with a 110v charger,which ...by KayakDan
Wed Mar 10, 2010 1:18 pm
Re: Battery Drain problem
... to run the cooler, neg. to neg. pos. to pos. for 12 volts. Use battery cables connecting the two and not jumper cables. I use this system for my house deep cycle bateries and a starter battery for ...by DaveB
Mon Jul 20, 2009 3:50 pm
Topic: Battery Drain problem
Views: 312 Jump to post
Bow Towing-Eye Strength
... dead from trying to start the engine and so I went below to use the jumper cables for the emergency battery. It still would not start. (note to self: what I though was ...by Wind Chime
Mon Jul 13, 2009 2:34 pm
Topic: Bow Towing-Eye Strength
Views: 314 Jump to post
Re: Prelude to a lightning strike
... posts seem to be missing is gthe concept that the reason you put down jumper cables is not so they will take a whole lightning bold, but so that the chage will be disapated ...by Hamin' X
Mon Jun 15, 2009 8:51 pm
Topic: Prelude to a lightning strike
Views: 430 Jump to post
... posts seem to be missing is gthe concept that the reason you put down jumper cables is not so they will take a whole lightning bold, but so that the chage will be disapated ...by blue angel
Mon Jun 15, 2009 8:07 pm
