In addition to the "start" battery I was planning on installing a pair of Walmart Group 24 or 27 "house" batteries as the Admiral expects many of the comforts of home on our
Pros-Cons?
Any advice?
Russell
I prefer AGM as wellHamin' X wrote:I prefer AGM type batteries, due to low internal resistance, low self discharge rate, ability to regularly cycle to as low as 20%, no gas discharge, extended life and no spill. If you go with golf cart batteries, be aware that the GC designation is a size and not an indicator of construction. True golf cart batteries are of solid lead plate construction and not the sponge lead of cheaper types. The only way that you can be sure is to stick with the major brands, such as: Crown, Deka, or Trojan. You won't find these at the discount stores and they aren't cheap. With their low internal resistance, you can use them as a starting battery as well.
When going with 6 volt golf cart batteries, a pair of them are used, hooked up in series, so they operate at 12 volts. We're set up that way for our house loads, which include an Engel frig. They've been doing a good job for 5 years. The 65 watt solar panel helps keep the batteries up, so we never draw down below half discharge. The golf cart batteries are installed in the battery box aft of the galley, and the ignition battery got moved over to the bilge area where the ice chest is stored.March wrote: Likewise, with the batteries: you want to go 6 volts? there are advantages and disadvantages to that. Until proven otherwise, the 12 V batteries make more sense (to me).
True true...hydrogen doesn't even stay mixed in our atmosphere, it is so light - it keeps rising to the very top and floats on the top of our atmosphere!Catigale wrote:You guys are over thinking this. Go on the web and try to find accounts of boats blowing up due to hydrogen from batteries. Good luck.
Cars dont do it either. Hydrogen has molecular mass of 2 amu, about 1/15 that of 'air' so it whisks away awfully quickly and reaches for the stars.
