This is the keel pivot bolt I replaced when I first got the boat - it's in good shape and does not leak:
Here is the bad hole for the locking pin:
Here is a pin that fits the keel hole showing how enlarged the holes in the hull have become- this pin has no head on it and it is the diameter of the keel hole:
I guess the obvious answer is to add fiberglass and resin, then re-drll the hole. The problem is that it will be difficult to drill the hole in the exact place to line up with the keel after it is repaired with the boat on the trailer. The other problem is that these areas are very difficult to access - especially the inside hole. One idea I have is to reach up under the boat, apply some tape to the insides of the holes (assuming I can get my hand up in there), then fill them inside the cabin with West Systems epoxy and filler and some glass. After it dries I could simply drill a new hole and hope it is in line with the keel hole. If not, drill it a little larger until it fits, then live with a small leak. If I drill the hole centered with the big hole shown in picture two, it will be pretty close.
I would like to be able to insert a pin from the outside and not have to reach up under the seat and put a nut, then tighten each time I want to lock down the keel or retract it. I plan to put a swinging door on the inside of the big hole that fits tightly and will be slid closed after inserting the pin - this will hold the pin captive and also prevent splashing inside the cabin in the event it does leak a little - any water would be contained under the seats where it can be pumped out with the sump pump if necessary.
Is there a better solution?
Thanks in advance for any help.
Aubrey Scott in Texas
