mag-neeetiiicccc....ya can't go yet, you have to at least stay and watch RS's videos with us!
Okay, here's a look at one of the interesting points brought up by the "we don't really have all the right information" posts...I'm a mechanical engineer by education, and a really practical hands-on mechanically-inclined trouble-shooting field guy, just so you know I'm not just wishing I understood physics... I say that because I don't want you to tire of my explanation if I'm saying things you already know...bear with me and read on a minute...
The issue I see that nobody has been able to adequately address, and which you (magnetic) have not adequately acknowledged is that the Mac hull on the M is NOT a displacement hull AT ALL. It is technically a hybid, but it IS a planing hull, and one with a tight V, a flatter bottom, etc. It DOES NOT act like the other displacement hulls on regular sailboats, which NEVER ride up out of the water at all.
The Mac hull, any planing hull for that matter, will BY PHYSICS rise in the water when moving due to the forces generated by any movement through the water - the design/shape is such that the movement of water under the hull produces an upward force. The concept of planing itself is an exchange, so-to-speak, where the force needed to keep the boat afloat comes fully from the movement of the boat through the water, no longer by the displacement of water by the hull.
In a displacement hull, it is exactly the opposite, the forces required to keep the boat afloat (buoyancy to us) come solely from the displacement of the boat in the water, regardless of the speed of the boat through the water. It is NOT designed to produce lift as the boat moves through the water - it is designed to displace the water around the hull efficiently.
In the Mac, you're going to get SOME lifting force as the boat moves - if the planing speed for a Mac is...what is the planing speed, 15 kts? If so, then 6 or 7 kts is nearly half the planing speed, and you will have some lift being generated...the boat is not displacing as much as it was sitting still...period. IT HAS TO do that or it will NEVER reach plane! By rising out of the water, you lower friction, you decrease the amount of displacement of water required... That said, it is possible that what you could call the "theoretical hull speed" of a Mac actually INCREASES with speed...it's hull-displacement-limiting factors get lower and lower as it goes faster thus allowing for a higher theo-hull-speed...and if, as you say, the beating speed is some percentage of the theoretical hull speed, then it IS possible that a Mac underway could actually reach a higher-than-expected speed when beating (or sailing any other way for that matter).
Am I saying it has been done? No...I'm merely pointing out that there are..."issues"...that COULD theoretically counter the physics of displacement hull design upon which the other information is based...I say let's give RS a chance to prove himself.
And Highlander, I'd like to buy a license to cutter-ize my S when I get it.
