c130king wrote:Gypsy wrote: We established the fact that the law (at least in the U.S.) calls for an all around white light on top of the mast . Whatever you do at lower levels is added protection , but it must be in addition to the light on top of the mast.
I don't believe this is true. I hang a Davis Mega Light from my backstay as my only anchor light. I thought Rich (Hamin' X) or somebody posted some guidelines that stated that it was fine to have a light lower than the mast head...the mast would not block enough of the light to be a factor.
FWIW.
Sailing on König
Rule 30 : Anchored Vessels and vessels aground
(a) A vessel shall exhibit where it can best be seen :
(i) in the fore part , an all around white light or one ball ;
(ii) at or near the stern and at a lower level than the light prescribed in sub-paragraph (i) an
all-round white light.
(b) A vessel less than 50 metres in length may exhibit an all around white light where it can be best instead of the lights prescribed in paragraph (a) of this Rule.
I copied the above , straight out of the rule book , my friend gave me , which is 'Nautical Emergencies ' and contains the COLREGS
I copied this from the other thread on anchor lights . A single masted boat must have an all around white light on its mast . You can have a lower light at or near the stern , but it is in addition to the all a round light forward
