Hows this for a battery charger/generator,small but expensive
12volt 55amp and weighs 13kg
2.5hp honda 4st and bosch altenator
Good backup for the solar panels and invertor
Read further back in this thread for my comments... and you might also search for 'honda generator' using the search field at the top of this page, since there's lots of information about them on this forum, including comparisons with other gensets.Tide Over wrote:Do you or for that matter, does any body have any experience with the Honda EU200i or the EU1000i generator/inverter? I appreciate that they are expensive but am wondering if they re worth it as I do quite a few all day hauls and expect to do 2/3 day ones next year.
Not being that knowledgeable with electricity, if I could keep my batteries charged which are providing the current for all my instrumentation on my 26X ,plus starting up my outboard why would I need anything more than the EU1000i if it will keep my batteries fully charged?kmclemore wrote:Although it is extremely light weight and small, the EU1000i is somewhat low-powered and you're likely to hit situations where you wished you'd had the larger EU2000i. Indeed, if I'd had it to do all over again, I'd have bought an EU2000i instead of the EU1000i. However, if all you're going to do is charge your battery, they both produce *exactly* the same 12v amperage (my Xantrex measures it @ 8 amps), so buy the smaller one.
Just call me Kevin. (or Mr. PennybagsTide Over wrote:Thanks for the good advise kmclemore.
One note on the EU series gensets - if you are going to run them in 12v mode (i.e. you've got the special "DC Charging Cord", pictured below, needed to connect the generator directly to the battery for charging) you *must* run the generator in full mode, NOT economy. This is a major consideration, since in 12v mode you do have more noise than in economy. Having said that, it's still pretty quiet, just not as quiet as in 110v 'economy' mode.moondancer wrote:I just purchased the EUI2000 and am happy with noise and output. ..... the rpm's didn't even go up and the lights did not dim. This is running in the economy mode.
If it is just lights and accessories then the 1000W will easily be enough. Even a small AC/DC fridge is only pulling a 100W so the EU1000 would do.Not being that knowledgeable with electricity, if I could keep my batteries charged which are providing the current for all my instrumentation on my 26X ,plus starting up my outboard why would I need anything more than the EU1000i if it will keep my batteries fully charged?
