The gate valve for my 26M ballast tank broke where the handle rod connects to the gate valve (inside the valve body). Fortunately, this occurred when the boat was on the trailer
My question is, what forms the seal between the valve assembly and the ballast tank opening in the hull? Is there a rubber gasket, or do I use marine sealant? I found plenty of discussions on this forum related to the valve, but not much about the seal.
Another thing. The heads of the 4 screws that attach the valve body to the boat are somewhat corroded (the boat spends about half the year in a slip in salt water). I hope there is no problem loosening these. Any tips?
Roger
