Mac 26m Mast shape changed from 3x5inch to 3x4inch ?
fireant
Post by fireant »
Hi all,
I need a new mast cap.
I have been told by the local dealer (who was told by the factory) that the :macm: mast hasn't changed shape.
However the people at BWY tell me there are two shapes. the new one is 3x4inch and the old shape is 3x5inch.
Can someone tell me who's right ?
Phill S
yukonbob
Re: Mac 26m Mast shape changed from 3x5inch to 3x4inch ?
Post by yukonbob »
i would listen to bwy.
fireant
Post by fireant »
I think so too .. but I need to find a cap.
BWY don't seem to have one available.
yukonbob
Post by yukonbob »
One guy on here did a home made job with a cottage cheese cont lid on a s or a v. Sure someone could come up with something better...?
:idea: Why not go straight to the horses mouth and call MacGregor :?: What do you have to loose :?:
I don't know who you spoke with at BWY, but you can also try sending "bwygirl" either a "PM", or an e-mail.
fireant
Post by fireant »
Yes .. I guess I had better ....
The dealer said he called Macgregor though.
parrothead
Post by parrothead »
Here's a link to the current drawing on the MacGregor web site's "suppliers' corner" -- indicates it is 26M mast shape "version 4", dated from 2006 -- so presumably correct for your 2007 :macm:
http://www.macgregor26.com/suppliers_co ... st-26m.pdf
fireant
Post by fireant »
Thanks for that.
I measured mine ... it's 5inches .....
I have emailed BWY .... I will let you know what they have to say.
Why just not fabricate a new one out of Alum it's not that hard !!
Terry
Post by Terry »
BWY is absolutely correct! The factory no longer supplies the 3 X 5.25 mast because the supplier found the extrusion process to be too complicated and expensive so now all new masts are 3X4. The upside is that they can make them all 30' and use them on all past models by just cutting them to length. I am also told that the aluminum channeling is thicker so stronger but I have not measured it.
I had an accident with my mast and creased it bad, and when I tried to replace it I could not find the same size. Fortunately BWY had one left in their yard, it only had a slight dent near the steaming light (cosmetic) so I got a decent price on it. If I ever have to replace it again I will have to get all new hardware to fit the different shape mast that I will have to buy. Anyone with the old 5" teardrop mast should take good care of it because it is not replaceable, you will have to get the smaller 4" teardrop.
Too bad, the 3x525 mast is significantly faster. On a blue hull and 3x4, you'll practically be sailing backwards..
pokerrick1
Sailboat: Venture 23
Post by pokerrick1 »
Highlander wrote:Why just not fabricate a new one out of Alum it's not that hard !!
Sure - - - I'll get my fabrication tools out and get right on it :!: :!: :!: :D :D :D :D
Rick
fireant
Post by fireant »
Thanks for sorting that out Terry.
You would think MacGregor would still supply the mast caps for the old one though !
Rick
Come-on Rick.
Its not that hard even some old plastic cutting board will do Duh!! :D :D :D :D
8) J
Terry wrote:BWY is absolutely correct! The factory no longer supplies the 3 X 5.25 mast because the supplier found the extrusion process to be too complicated and expensive so now all new masts are 3X4. The upside is that they can make them all 30' and use them on all past models by just cutting them to length. I am also told that the aluminum channeling is thicker so stronger but I have not measured it.
Actualy Terry.
You'd been better off with the smaller mast & adding a second set of spreaders with a third set of shrouds way much stronger and a lot less weight aloft
PS you'd maybe able to use your old hardware I'd think :idea:
