used Venture 17
datamarc
Sailboat: Tattoo 26
used Venture 17
Post by datamarc »
I recently purchased a used Venture 17, I think a 1996, and it does not have a rudder, a boom, or an owner's manual. Anyone know where I can purchase these? Thanks, a newby.
Capt_Skippy87
Sailboat: Venture 2-24
Re: used Venture 17
Post by Capt_Skippy87 »
Hi there, congrats on your purchase of the Venture. You can find a manual in the resources section of this sight. as far as buying a boom Dwyer Mast Co. is the best place to start. www.dwyermast.com. Rudders can be easily constructed out of redwood all you need to do is pick a style and find the hardware. Hope this helps
Hamin' X
Re: used Venture 17
Post by Hamin' X »
The V-17 has not been in production since 1975. I hope that you were not led astray by the seller.
Lloyd Franks
Re: used Venture 17
Post by Lloyd Franks »
Lots of boats are no longer being made...Why would that be an issue?
Hamin' X
Re: used Venture 17
Post by Hamin' X »
He indicated that it was a 1996 model.
Lloyd Franks
Re: used Venture 17
Hmmm. Didn't see that. Good point.
Ivan Awfulitch
Re: used Venture 17
Post by Ivan Awfulitch »
Check here for the manual:
http://www.tompatterson.com/Sailing/Sai ... ling20.php
Also, Bluewater Yachts has some parts available for this boat. I believe that Ida Sailors still has a rudder available for that boat, but it's a bit on the pricey side.
Link to Venture 17 Manual
datamarc
Sailboat: Tattoo 26
Re: used Venture 17
Post by datamarc »
not really led astray, just found some old papers in the cabin and owner of boat was admitted to nursing home and unavailalble to talk to.
but thanks to all for responses.
Hamin' X wrote:The V-17 has not been in production since 1975. I hope that you were not led astray by the seller.
