I just my first sailboat (1984 M25) and have learned a TON by reading this forum. I got the boat as a major project boat. It was flooded inside. There was also a 1988? Honda 7.5 motor on the floor stored in the WRONG position. So there was a water and oil scum line around the interior. At least I knew it was water tight on the bottom.
8 hrs of pressure washing, a pond pump, a lot of elbow grease and the hull is clean. I still need to:
rewire
install bilge pump (there is none right now)
replace standing/running rigging
get a motor ( I just saw a 2004 Honda 5 for $350, but it was a short shaft and did not have the 12 v out) bummer
redo headliner/cushions
redo interior outdoor wood. (I have a friend who is a cabinet maker and can help me out)
The Swing down keel moves freely. However, it is pretty rusty. It looks like it would be about 5-600 bucks to take it out, get it blasted and painted. I think I'll wait on that one though. I want to make sure everything else is ok. I'll trailer it, so the keel will be dry most of the time.
I wanted a project and I sure got one. I'll be a day sailer/fair weather for a while.
I want to run the halyards aft. I'll probably stick with the hank on jib for now, but I'd like to have a roller furler in the future.
So I have a couple of questions:
What should I consider the minimum horsepower outboard for this boat?
Is it ok to drill holes in dinnette and head area where there is a groove for water to collect? At leas this way it could drain into the bilge.
What is the most common/best bilge pump and thru hull location?
Any other words of wisdom?
I appreciate it!
edit: I'm in the Santa Barbara, CA area
Erik
