Divecoz wrote:Suggestion only.. Beach with no ballast..or If you come in with water ballast in place she'll stop sooner ( deeper by a few inches) and later if your set up to do so? You can pump it out making the boat, close to 1000 lbs lighter.
Kedge set, two anchors in deeper water and use port and starboard winches to kedge/winch her off the sand.
Thanks for the suggestion, so, I could exploit emptying the ballast making the boat lighter in order to free the boat off the sand,
, however,I noticed that althought the bottom of the boat was already laying on the sand, still the transom valve was under the sea level, would in this case the water flow out the ballast? Could the pressure of an air pump (I mean one of those used to inflate beach toys) through the air valve under the V berth suffice to blow the water out? I think I'm going to experiment next time
