I'm hoping some of you can give me some advice. Over the weekend I was at Dana Point testing out my new to me 2001
The boat was somewhat lightly loaded with mast and boom aboard, but not much else. My motor is a 2001 50 hp Johnson 2 stroke with a 4 bladed Vortex prop by Michigan Wheel. This prop is a 11.5 x 9 with a little cupping and big dog ears like was recommended by the posts I've read in the past. My motor is fairly low and I can only go down one more hole.
I tried calling Michigan wheel, but they seemed to believe the prop was correct and didn't know what to recommend except to buy another prop with 3 blades and more pitch.
Is this really the route I should take? It seems contrary to the posts that I have read.
I'm tempted to try out those composite Piranah propellors so that I can economically experiment with different pitches, but I'm really confused as to why the current setup is not working properly.
Does anyone have any recommendations or know of a dealer in southern california / near Orange County that will allow me to test several props?
Thanks for your advice in advance.
Randy
