Been there...done that...got the t-shirt...and the red-face from embarassment...jschrade wrote:I can add that going into the slip is no problem but coming back out, it will add some confusion! My daughter was backing the boat as said the helm was not responding. I thought possible the steering link had broken but I had for gotten to link the motor to the rudders.
This is what I have currently (but wing-nut and spare wing-nuts versus cotter key). Easy to do...but...I definitely get some interference between the linkages connected to the motor the steering arm that comes out of the port side of the engine well. When I turn fully to port and that arm is fully extended it will hit/catch on the linkages that connect the motor to the lock-down bolt and sometimes it will keep me from getting full port turn or the bolt in that steering arm will actually get caught in the linkage and I can't turn the wheel back to starboard. When this happens I just lower the motor a little which will twist those linkages enough to free up the steering arm.jschrade wrote:I have the factory nut and bolt system. It's not really the hassle that it gets described as and it's simple and I cannot imagine how it could fail. I have extra screws and nuts in case I drop one. Setup/Breakdown less than a minute. I changed the nut and bolt for a cotter key and it works perfectly.
I am switching to the BWY system to see if I can avoid encountering this situation in the future. I will try to take some pics of this when I am out on my 2-night solo adventure this weekend.
