Is there a larger size fuel tank that will fit - without any cockpit modifications?
26X fuel tanks
- dlandersson
26X fuel tanks
My 1997 26X came with two 6 gallon fuel tanks - one on each side of the cockpit.
- mastreb
Re: 26X fuel tanks
My
two 12 gallon tanks. It's enough fuel to last the entire summer for me. They came with the boat, but I'm pretty sure they're the Moeller 12 gallon low profile tanks from West Marine. I don't know if the fuel lockers are the same size however. Perhaps someone with an
knows?
- dlandersson
Re: 26X fuel tanks
Thank you - the web site search function wasn't working earlier - now it is.
Thinking of going with the Neptune 6-gallon tanks.
Any input is deeply appreciated.
mastreb wrote:Mytwo 12 gallon tanks. It's enough fuel to last the entire summer for me. They came with the boat, but I'm pretty sure they're the Moeller 12 gallon low profile tanks from West Marine. I don't know if the fuel lockers are the same size however. Perhaps someone with an
knows?
Retcoastie
Re: 26X fuel tanks
Funny you should bring this up now. I just happened to watch the X promotional video that I got before buying our X yesterday. In that video, it states the X comes with two NINE gallon tanks. Mine came with six gallon tanks. Did anyone get nine gallon tanks? What are they?
Thanks
Ken
Thanks
Ken
Re: 26X fuel tanks
I have a 75 litre tank in sb side of the bed under cockpit - i dont need more than a normal bedsize around 1,5 meter wide and i need the the space in cockpit for all other kind off stuff & tinghs than tanks .... And the weigth in bottom is better for balancing the boat - and it is space for several heavy batteries too beside the tank or in the rear end of bed ....
- Chinook
Re: 26X fuel tanks
A search should provide lots of info on this topic. I have a pair of 12 gallon Tempo tanks in my fuel lockers. They fit without modification, however, I did have to cut holes in the cockpit seats to provide access for filling the tanks. I installed a pair of those round access covers, and it has worked out fine. Only problem is that the Tempo 12 gallon tanks are apparently no longer available. There may be other 12 gallon options out there. You should find several posts by guys, such as Duane Dunn, who prefer using 4 six gallon tanks. They fit fine in the lockers, and are small enough to tote when full. 12 gallons of fuel is way too heavy to carry.
- Don T
Re: 26X fuel tanks
Hello,
Moeller now makes a Copy of the Tempo LPT12 tank. I saw one at West marine a week ago. Price is up, however, because of new federal regulations about permeation and evaporative loss. It's just a hair smaller than the Tempo, so it slides right in.
- Andre Emmenegger
Re: 26X fuel tanks
OMC makes a 6 gallon tank that fits into the locker easily, with very little cutting. You can put two in per side for a total of 4 tanks and 24 gallons. The best part of me is that they are easy to handle, and you can adjust your fuel load for your trip. To switch between them, I wait until the engine starts to motor down, and then with idle thrust, I can switch before the motor dies.
- dlandersson
Re: 26X fuel tanks
Link?
Don T wrote:Hello,
- dlandersson
Re: 26X fuel tanks
Link?
Andre Emmenegger wrote:OMC makes a 6 gallon tank that fits into the locker easily, with very little cutting. You can put two in per side for a total of 4 tanks and 24 gallons. The best part of me is that they are easy to handle, and you can adjust your fuel load for your trip. To switch between them, I wait until the engine starts to motor down, and then with idle thrust, I can switch before the motor dies.
- Bobby T.-26X #4767
Re: 26X fuel tanks
many X owners, including me, use 4 of these in their existing, non-modified cockpit lockers.
this way, if needed, you'll get a full 24 gallons of fuel. and, when you need to "re-load", they can be easily removed from locker and transported to the local gas station to save $$$ vs purchasing expensive fuel at the marina.
also, if you only need 12 gallons for a short day trip, you can remove two tanks and use locker space for storage.
Bob T.
"DāBob"
Dinghy Motor: '06 2.5-Suzuki
Re: 26X fuel tanks
Can one of you guys with the 6 gallon tank that fits without cutting pls post a model number of the tank.
Thanks.
ron
Thanks.
ron
trdprotruck
Re: 26X fuel tanks
http://www.amazon.com/gp/product/B000MT ... HMWG8DAXPH
hope this helps.
-Randy
hope this helps.
-Randy
captronr wrote:Can one of you guys with the 6 gallon tank that fits without cutting pls post a model number of the tank.
Thanks.
ron
Re: 26X fuel tanks
trdprotruck wrote:http://www.amazon.com/gp/product/B000MT ... HMWG8DAXPH
hope this helps.
-Randy
Thanks.
ron
WOW!!! they have really gone up in price. i remember paying about $20/tank several years ago.
Bob T.
"DāBob"
