06HARLEYULTRA wrote:... I have been reading about the Standard Horizon HX 851, as it has many good features.....
On the negative side, it has a limited battery, and no MOB button.
My intended usage would be inland lakes at first, then close costal and ICW in the future. Rich
It looks like you would spend the $270 on the HX 851.
For a little more you could get the GX1150 Eclipse with the DSC for $130.00 and the handheld HX 280S for $106.00. We bought a Garmin Map 76, non-color, off of E-bay for less than $80 that had never been used. There are others on there right now.
Hook the Garmin to the GX1150 and you would enable the DSC function of the radio and the Garmin would give you tides, position, the MOB and the option with a computer of running free SeaClear to map routes and export the waypoints into the Garmin from the computer. We went over 400 miles in Florida doing just that.
Now you have a fixed radio that will pick up NOAA weather for long distances and also get out there and transmit and receive long distance (of course you need an antenna and coax, but this doesn't have to be at the top of the mast). You have your handheld and you have a GPS, all for about $316 plus the antenna and coax. Not to much more than what you would spend on the HX 851.
You would have yourself well covered now and in the future for just a tad more,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
