So I launched my SeaSaw
I'd had the motor professionally winterized last year. I pulled off 2 pieces of tape over the prop (one over the end, the other around the prop's neck). There were no other tapes.
Motor worked fine until I throttled it up, then the overheat alarm started screaming. The engine got very hot. (I hope I haven't permanently damaged it.)
So now I can't figure out what's wrong. Apparently, it should be "piddling" water from the "nape-of-the-neck" (you can tell I'm not a mechanic), which it isn't.
My mentor and my Googling seems to point to a failed impellor, which if true, I will repair. (I don't know when the impellor was last serviced).
What I want to know is this: should I confirm the problem, or look for other solutions, before getting a new part and replacing it?
