YesRobertB wrote:Does that tape come in BLUE?
According the the website: "The extra polymers infused in the blue makes it go on 2% faster than the standard black tape. That's why we named it 35."
Cool!
I always believe the best thing come in bluekmclemore wrote:Nope. You can only get this high-performance tape in black with a white container.RobertB wrote:Does that tape come in BLUE?
As with many high-performance things, the best is rarely available in BLUE.
Confused emoticon? The 18 gauge wire is only 24-29 cents per foot (depending on qty) and should be sufficient for nearly every circuit.This looks like good wire but why the extra expense? You can get duplex marine grade wire 12 AWG for $0.79 per foot http://tinnedmarinewire.com/wire/index. ... 2031983829 - the Mil-Spec wire is $.99 per foot for single conductor. You could use several hundred feet of the stuff - it adds up.
