So we've discovered that we need new lines....and we've chosen Cajun Ropes in Canada to get them from....
I am a bit confused though, about the running rigging as well as sail placement....
Ok, so our Mac came with the main, a 135% genoa, and a jib. The jib is still in the bag, we have no idea how to put it up, haha!
We started off using the genoa, and then worked our way to using the main. Can I tell you how much we love roller furlings? I would love to get the main on one....has anyone done that? Who did you go through, what kind of modifications must be done? How much was it?
Edit: Was just reading about the furling systems for the main....guess it's not the best idea:-/ Oh well!
Anyway....we have ordered new custom sails from Judy....very excited about them. A new main, 150% Genoa, and a 100% jib and a assym. spinnaker. I told Cajun this, and they said the 150% will require longer lines by 5-10 feet, and so that's what we will do in preparation for the new sails.
My silly newb question is this:
Our Genoa is on a roller, and we like the rollers! Can the jib be put on the same one (do you swap them?). Or do you have to get a separate roller? Do I need different lines for each, and if I was to get the jib on the roller, would this change the specs for the lines? Does this make ANY sense? Ha ha!
Anyway....we have been learning so much in the last while. We managed to get going 5.8 MPH under sail....it was exhilarating! The boat didn't heel too much (I hate when it goes over a certain angle....eeeek!). And we did that thing where the genoa is out one way and the main is out the other....forget what that is called. We we cruising then! Too fun!!!! We are hooked!
Thanks so much in advance:-)
Cat
