SOOO EXCITED!!!
Trying out the trailer..
Kevgrn114 wrote:So just to sum up, after 17 years of drooling, saving, giving up, settling on cheaper boats that didn't fill the void, I have found the Mac for me.. The guy was very nice, took us out on the bay and sailed and motored for a while. He even let me hook it up to the Jeep to make sure It could pull it ok. AND he agreed to hold it for me with some cash down until I could get the checks I was expecting and get them cashed.. I have the cash now and am going to go pick it up on the weekend of the 17th. About 4.5 hour drive. Going to make a weekend of it. Friday hand over the cash, go to TPWD and do the title work. Saturday He is taking us out again for a while then back to get it de-rigged for trailering, then driving home Sunday.
SOOO EXCITED!!!
It's not a difficult project, but if it's the original trailer, the surge coupler was welded to the frame and you would have to cut or grind the welds off to replace it. I mention this because it's a near-certainty that the master cylinder is shot and will also need replacing. When I changed the brakes on mine over to disc, I elected to replace the coupler also. Same make and model (used to be DICO, now it's Titan, but can't tell them apart), so I ground off the welds, drilled two holes, and bolted the new coupler on. The cost of parts to rebuild the coupler was almost as much as a new coupler, so I went with all new, and being bolted on now, I can remove it for service if needed. From the pictures, it looks like yours is the same (DICO/Titan), but replaced at some time, as it's not painted black.Kevgrn114 wrote:The hitch of the trailer still has the surge piece attached so I would only need to add the brakes and lines. I was looking at etrailer.com and they don't look to awful for price.. I will likely add them.
Surely it can't be any worse than changing the springs, tie rods, and ball joint on our RV:-)
I have a dual axle.... it can still sway, it all depends how you load the boat (CG over the wheels). The more weight you tow the more important breaks are, and adding an extra axle just added at least 300 lbs to your tow weight. You need breaks. The surge breaks work best, they automatically slow the trailer down when ever it tries to push against the tow vehicle- like when your going down any incline hill on the highway. I would list adding breaks as your number one thing to do.Kevgrn114 wrote:Thanks! Yeah, the trailer just had new axles, springs bearings and all put on. The only thing I'm concerned about is he didn't put trailer brakes back on. Although he stated he had never stopped hard enough to get them to engage. I guess I'l see how it goes and add them later if I feel they need it. I'm most worried about sway which from reading on here is address by the dual axles.
...wait.. the mast comes down?
Since they engage automatically, it's hard to know if/when they engage. They just happen and you wouldn't know it. Well, unless they don't and the rig pushes your tow vehicle ahead.Kevgrn114 wrote:Although he stated he had never stopped hard enough to get them to engage.
Quite often whet I rig and raise the mast in the lot just before backing down the ramp, I will unplug my trailer wiring. It never fails to catch me by surprise when the trailer brakes lock-up while backing toward the ramp and I am caught by surprise and say to myself WTF?RussMT wrote:Kevgrn114 wrote:Since they engage automatically, it's hard to know if/when they engage.
