John
Ormonddude wrote:Personally I seen to many Crimps fail I am all for the heat shrink but Solder the connections Whenever possible - do yourself a favor pic up a really decent soldering Iron - I purchased one of these and its one of the best investments I have made - http://www.amazon.com/Soldering-Station ... ng+station just take the plastic protection off the tip and its ready to go LOL So many foolish people seem to leave it on and then think its broken
25 years as a lineman....Klein good.Divecoz wrote:If you have seen crimps fail, The Operator did something wrong.. The wrong tool or the wrong size terminal..I always carried two or more sets of " Lineman's Pliers" Manufactured by both Klein and Ideal.. Ideal has a built in sta-con crimper , but its a One Size Fits all and it truly, ONLY fits #12 AWG.. For our general purposes, there are only 3 sizes of terminal's that we use #12, #14, and #16 . If they are insulated they are always color coded Yellow #12 Red #14 Blue #16..
If you like soldiering, more power to you.. Its laborious and messy and it can often provide a cold joint.. You must heat the barrel portion of the terminal to the same tempature as the wire...Thats easy to accomplish on #22 = maybe #16.. Personally, I would be amazed if that 1.5 MM tip properly heats the barrel of either #12 or #14 terminals..Ormonddude wrote:Personally I seen to many Crimps fail I am all for the heat shrink but Solder the connections Whenever possible - do yourself a favor pic up a really decent soldering Iron - I purchased one of these and its one of the best investments I have made - http://www.amazon.com/Soldering-Station ... ng+station just take the plastic protection off the tip and its ready to go LOL So many foolish people seem to leave it on and then think its broken
kmclemore wrote:I'll just chime in... I solder *every* connector or join. Even 'crimp on' connectors get soldered, too. Never had one fail yet.
