Tried and proven on Cuttyhunk every year.2 Rear anchor to reduce the Mac Dance
The swing angle in 10-15 knot winds is reduced from about 100 degrees without mushroom to about 30-40 degree tops..
Catigale wrote:Tried and proven on Cuttyhunk every year.2 Rear anchor to reduce the Mac Dance
vizwhiz wrote:Divecoz, I think you missed the points...there were two conversations being had at the same time...
Conversation One:
Attaching the mushroom anchor to the chain/rode interface acts as a snubber. As the boat moves back and tensions the rode, it has to lift that mushroom anchor off the bottom just by the tension in the rode. The tension needed to lift that mushroom anchor, and the amount of line that goes from angled to straight, works like the rubber snubber in your system. The explanation of the Sentinel is the same functionally, but the smaller weight is lowered straight down from the bow of the boat, not out at the chain/rode interface.
Conversation Two:
Cat uses the mushroom anchor off the stern to cut down on the swing. He was just explaining a second use for the same mushroom anchor as justification for having it aboard. Cat was not saying that having it attached to the chain/rode interface cuts down on swing at anchor...
Sooooo when are you getting down here?? Where are you landing?
Cool! Once you get moved in and settled, send me a PM and we'll get together!Divecoz wrote:I will be in P.C.Fla. on The 20th of Oct. Moving into the house on the 22nd..
vizwhiz wrote:Cool! Once you get moved in and settled, send me a PM and we'll get together!Divecoz wrote:I will be in P.C.Fla. on The 20th of Oct. Moving into the house on the 22nd..
Divecoz wrote:Viz I guess I wrote it poorly.
I get the anchor snubber idea. I just never had "luck" with those round bottom Mushrooms doing anything but dragggging as an anchor..
Conversation One:
Conversation Two:
DaveB wrote:Chuck,
Useing a small (5-8 lb) rubber coated mushroom anchor at the rope to chain splice with 30 ft. of chain will give you a much better shock and holding power in heavy wind & waves. I assume this is much like you mentioned. The rubber coated will save deck damage.
chuck wrote:A Sentinel is a big help when you do not have enough chain. I use one in the San Juans and Puget Sound all the time.
"Using an anchor weight, kellet or sentinel
Lowering a concentrated, heavy weight down the anchor line – rope or chain – directly in front of the bow to the seabed, behaves like a heavy chain rode and lowers the angle of pull on the anchor.[23] If the weight is suspended off the seabed it acts as a spring or shock absorber to dampen the sudden actions that are normally transmitted to the anchor and can cause it to dislodge and drag. In light conditions, a kellet will reduce the swing of the vessel considerably. In heavier conditions these effects disappear as the rode becomes straightened and the weight ineffective. Known as a "anchor chum weight" or "angel" in the UK"
Chuck
chuck wrote:DaveB,
I use a snatch block and line to lower my 10 lb weight where I want it. Part way or all the way down. I pull it up when I am ready to move. That way I do n ot have to lift all that weight when lifting the anchor. At 77 that is important.
Chuck
DaveB wrote:Chuck,
Chuck
Divecoz wrote:We would love to DaveB but I am sure we will be in Full Blown Frantic Mode getting the remodel done before Christmas..
Love the picture, says a thousand words.vizwhiz wrote:
RussMT wrote:Love the picture, says a thousand words.vizwhiz wrote:
I'm not comfortable with #1 and #3 above. If you have had success with it then go for it. Too much "stuff" close to the anchor to get tangled if the tide/wind changes. Typically at night, winds die and the boat goes totally slack on the rode. Winds often switch direction 180 degrees or so and I would be concerned about wrapping all that stuff up in the anchor. Chain alone seems to roll over the anchor and it resets.
Now #2 can be controlled by lowering the mushroom just above the bottom so it's out of harms way. This one seems the safest to me.
Frankly, 20' of chain is pretty heavy and hard to lift off the bottom if you have a lot of scope out.
The snubber has the anti-shock qualities, but so does a length of nylon rode. I'm having trouble understanding how it helps keep the chain on the bottom.
And tossing a mushroom off the stern probably works best in certain dragging on the bottom conditions. In the morning, you pull it up and find some clams for breakfast.
