26Mac X Drains
Weldon
26Mac X Drains
Post by Weldon »
When checking the battery charger located under galley stove on our 2001 Mac X I noticed water frozen in galley sink drain, also checked head sink drain frozen also and we haven't used the sinks, seems a venturie effect has occurred while heeling since the exit is under water. Using a micro furnace was able to heat drains enough to melt and drain the water. Does anyone know a reason why the drains are long enough to hold water?
Re: 26Mac X Drains
I don't see a reason they should be anything other than a downhill run to the through-hull, with no trap functionality. Unless someone replaced them with longer hose.
Ormonddude
Re: 26Mac X Drains
Post by Ormonddude »
Actually I seen in another post that a lot of people add a bend in the drains to hold water as a insect barrier so little stowaways cant get in and have their way with you! in other words its a fly and mosquito trap.
Azzarac
Re: 26Mac X Drains
Post by Azzarac »
A water trap is an interesting mod if you live in a warm climate but I think the sink stoppers are much easier and you don't have to worry about them freezing...
taime1
Location: Ottawa, Ontario, Canada 2004 Mac 26m, Honda BF50
Re: 26Mac X Drains
Post by taime1 »
Our PO had put in plugs for both the head and galley sinks on the outside, which was quite good for preventing water from going in and out. Wish I had noticed them before I needed them to drain out! :o
