Recently, someone posted a little piece from an older MacGregor factory website about the steering system.
I quote:
STEERING. The cable and drum steering has been replaced with a very strong rack and pinion system (with a safe working load at the tiller of 2000 pounds, as opposed to the old system with a safe working load of 300 pounds.) These new units are extremely strong and durable. They are easier to install and service, and offer much smoother steering. We have raised the height of the pedestal to take the longer rack. The new units are long and thin, and take up a lot less rome inside of the pedestal.
Now I am a bit confused (has happened before
Maybe someon on the list can explain this a little better, maybe there is even some sort of technical description/drawing/etc available relative to the steering system of a 2005 M
I thank you very much for your responses!
Best regards,
Kai
