I have started from brosing the BWY site, looking for 'must have' items for next sailing season for my
1. Single Line Reefing - is it really as useful as described? Can I install it on my
Sometimes I sail single-handed so I need every device that makes sailing easier and safer. If there's no need to go to mast for reefing, and it WORKS, then it is a must have item for me.
2. Halyards Aft Kit ??? Same question - does it really make life easier? Does it work with 's rotating mast?
3. Boom Vang Kit. Just tell me, will I see any better sailing performance with it (never tried that kit, never even saw one)
4. "Boomkicker" Solid Boom Vang ? The BWY site says it doesn't really work for M, due to rotating mast. However, at our http://macgregorsailors.com/catalog/pag ... /index.php some similar item is recommended for
However, there is another issue. How long are these "kickers"? I am coming to US to buy some items for my and to hand-carry to Turkey where I sail! If that items are oversized and I can't take them to the plane, then the topping lift is my only choice.
5. MAINSAIL CONVERSIONS ?
Actually, it isn't THAT hard for me to pull the line and feed the bolt rope to the slot with another hand, when raising the sail... In case it is the only advantage of that kit - should I save 200+ bucks?
6. Wind Indicator and Stand Off Bracket ? Would it improve my performance as helmsman? Right now I take a look at the flag behind me to see the direction of wind... Classical windex wind indicator - doesn't work for rotating mast, does it?
7. One of my rudders got hit when going out of river to the sea (there is some shallow place there!), so will I see better helm performance in case I change both rudders to ones from IDA/Ruddercraft? (One original rudder is 250 dollars, two from ruddercraft are no less than 725!)
I have searched the Fora here, googled the internet - and all I could find is "yes, rudders got better somewhat".
I am sorry to ask that many questions, but now I am located outside of US, where it is hard to get these items. Found some cheaper air tickets, and I am coming to US to buy these items in few days, so I hope to make RIGHT orders. THANK YOU
Any advice appreciated!
