Thanks for this Harvey.Harvey wrote:You might consider using a weight-distributing anti-sway hitch. Take a look at http://www.equalizerhitch.com.
It is the only weight-distributing hitch that works with surge brakes.
I have been towing my X for several years with both a Honda Odyssey minivan and a Ford Explorer using the Equal-i-zer and am well pleased with its sway control and leveling of my tow vehicles. Search the forum using my handle as a search term to see comments on its effectiveness.
The hitch was designed for RV-type trailers which have a "Y" frame tow bar. There is a crossbar made to fit the MacGregor single pole tow bar trailer frame. Check with the Equal-i-zer folks to see if they recommend using one. I use one, but I think another poster a couple years back said that the Equal-i-zer folks told him the crossbar was not needed.
Disclaimer: I have no connection to Equal-i-zer except satisfaction with the product.
Harvey
I was under the impression that weight dist hitched wouldn't work with our surge breaks on the Alu. trailer.
Now I have another option to consider.
As I've only trailered my
Hugh
