Sounds like a trick question.Newell wrote:To use the same mounting hole on the mast, how much should the forestay be shortened, 8-9/16?
Answer: Eight inches.
That one looks nice. We bought the cheaper one...BOAT wrote:Okay you guys, I did what you told me to do - I got that guage thing that you said was for our boats. It says PROFESSIONAL TENSION GUAGE MODEL PT-1 on it. That's the one you said I need to use, right?..
That is accurate. Looking straight down on the boat, the shrouds are swept out (side to side) and back, and balance each other side to side. Because they're also swept back, there's an aft component to their force that has to be balanced by the forestay. Whatever the shroud tension is, the forestay tension will be a function of that. Since the shrouds are mostly port-starboard, and only swept back a little, the resulting forestay force is relatively small, and also it's 'footprint' is much farther ahead than the spreaders are aft, so the 'leverage' comes into play. The end result is that the forestay force will be whatever it will be when the shroud forces are correct.BOAT wrote:“Fractional rigs with spreaders swept back: the forestay tension is balance by the upper shrouds.”
See above - the forestay balances the aft force component of the shrouds, and it holds the genoa.BOAT wrote:I guess that explains why they use a smaller wire on the front. The forestay does not really do anything but hold the genoa – I guess the major share of the mast pressure is supported by the side stays.
That's it.BOAT wrote:Anyways, if the instructions in the box mean anything I guess the forestay tension does not matter because it’s always going to ba a balance of the side stay tension. That sure makes things easy.
Not sure if I ever said which model to buy or not, but we paid a little over $70 a couple years ago....BOAT wrote:Hey Summer! You paid 97 dollars for that! MAN! YOU GUYS TOLD ME TO NOT BUY THAT ONE!! ...
