I have a E-Tec 60 HP Model E6ODPLSUM which was installed new in December 2006. It came with limited instruments (analogue-style RPM + warning lights for oil and temperature) but I would like more. I'm especially interested in getting live fuel consumption and engine temp readings.
I've made some enquiries on the E-tec owners Board and have been told that my model pre-dates NMEA 2000 compatibility which rules out Evinrude's I-Command system, but I gather that its EMM is capable of sending the data I want to Evinrude's diagnostic software on a laptop via an appropriate serial-USB communication cable. From the example I found here there seems to be a lot of data from the EMM, if only you can get to it.
My local dealer wants AU$170 for a cable plus a further AU$160 for software, which seems a bit pricey in comparison to the kits I have seen on Ebay here or here.
Has anyone had any experience of these suppliers or can you suggest other possible sources?
Thanks in advance for any suggestions
