How long is your rope?
vizwhiz
Post by vizwhiz »
So how much rope does it take to lift the swing keel from fully down to fully up (retracted) on an S?
My boat is on the hard still, but I'm making progress, and one of the things I am getting close to doing is routing the swing-keel lift cable up into the cockpit. But I can't drop the keel fully to measure the full run of rope I need to drop the keel fully (and then pull it back up). Anyone have that measurement or have their boat in the water where you can measure it please? Thanks in advance!! :wink:
grady
Re: How long is your rope?
Post by grady »
In my notes for my boat is 12 ft 1/4 line and 5 foot of cable only I do have 2 to 1 on mine. The 5 foot of cable is enough to go from the center board to inside the cabin. Then it is 2 to one for the line. From what I remember 12ft was plenty prior to the modification. Altho it is easier to cut a line shorter than to stretch it. :D
vizwhiz
Post by vizwhiz »
Sorry if I've confused, and thanks for the quick reply grady, but i'm trying to ask how much rope you pull when you pull up the keel? If you have a 2:1, which i'm thinking would be good to do, that should be twice the rope. So what i'm needing to know is how many feet does the rope move when you pull up the keel? Does that make more sense? :?
grady
Post by grady »
Ok was at my boat this weekend I have about 5 to 6 ft of travel so without the 2 to 1 would guess around 3 ft.
Sumner
Post by Sumner »
Just figure out how much down to the keel now for the way you want to run it and add about 3-4 feet and you will have it as the CB pivots so the length doesn't get much longer down or up. Our boat had and still has ...
http://purplesagetradingpost.com/sumner ... de-40.html
.... a SS cable from....
... the CB up to the top of the tube and to the turning block under the counter and then rope from there. We now have that on a 2:1 run out to the ....
http://purplesagetradingpost.com/sumner ... ng-19.html
...cockpit and really like the setup. I think I'd like to stay with the cable for the last part of the run. I think it is going to last longer than rope down in the water,
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
vizwhiz
Post by vizwhiz »
Thanks grady and Sum...
I wasn't planning on replacing the cable with rope, leaving the cable. I just need to know how much rope moves when you pull up the keel from all-the-way-down to all-the-way-up. I think grady got it, close to 3 feet, and with a 2:1 it will be 5-6 feet of rope pulled.
Thanks again!! ;)
Sumner
Post by Sumner »
vizwhiz wrote:Thanks grady and Sum...
Thanks again!! ;)
I don't see an easy way to have a 2:1 and keep it under the counter,
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
vizwhiz
Post by vizwhiz »
Sumner wrote:I don't see an easy way to have a 2:1 and keep it under the counter,
Sum
Oh, I completely agree Sum! Am not planning to!
Am going to route it up the back of the divider in the head like everyone else does, adding a 2:1 back there, then take it out the front of the cabin like you did ...doing the same thing all of you have done before. I'll just be doing it "blind", not having dropped the keel yet, and not being able to during the process...so I don't know from experience how much rope has to move to drop the keel all the way back down...that's why I'm asking...if the rope attached to the cable has to drop 3 feet, then I have to have that much movement of the center pulley in the 2:1 to let it all the way down. Hope that makes it more clear.
grady
Post by grady »
Sum
Yes it is possible! I will get some pictures.
grady
Post by grady »
Ok found one picture.
Had to move the lower block over slightly to just get enough travel. I ran cable out side and line inside. The 2 to 1 was done because I made a snug fit at the pivot point for the center board, enlarged bolt to 1/2 inch, added 15 lbs or so of lead to bottom of centerboard. This completely eliminated any banging at anchor.
vizwhiz
Post by vizwhiz »
Wow...you did the 2:1 under the galley. I hadn't thought about doing it there. I was planning to do it in the head on the wood bulkhead after re-routing the rope to come straight up out of the galley top next to the head. I think it was Sumner and someone else who posted the mod I was going to copy. I'll have to look at it again, as it may simplify things to keep it under there.
So when you release (drop) the keel, about 3 feet of cable feeds out?
grady
Post by grady »
vizwhiz wrote:Wow...you did the 2:1 under the galley. I hadn't thought about doing it there. I was planning to do it in the head on the wood bulkhead after re-routing the rope to come straight up out of the galley top next to the head. I think it was Sumner and someone else who posted the mod I was going to copy. I'll have to look at it again, as it may simplify things to keep it under there.
Yes there is just enough to get the centerboard all the way down.
I'm not sure how long it is...but I can tell you I always seem to be at the end of it. :P
vizwhiz wrote:So how much rope does it take to lift the swing keel from fully down to fully up (retracted) on an S?
