Tip of the day ...Post yours
Matt19020
Post by Matt19020 »
Getting the boat ready to put it in this weekend and I noticed the ballast drain gate valve was pretty stiff to operate...I put a little white lithium grease on the rod and the gate and the seal...works better then new!
yukonbob
Re: Tip of the day ...Post yours
Post by yukonbob »
Hook up steering linkage before you decide to leave the ramp. Makes things easier :D
Phil M
Post by Phil M »
How about " Attach the masthead fly BEFORE you raise the mast." :x
yukonbob
Post by yukonbob »
Had a buddy who forgot to attach his float and line to a brand new crab pot before he set it.
I have a funny feeling this is going to get hilarious...
Post by BOAT »
Take a couple of pool noodles from Walmart and slice them up the middle like your gutting a fish and put them on your spreaders before you roll the mast back and the spreaders won't scratch the top of the cabin
Harvey
Post by Harvey »
Before launching, remove the bolts or pins that hold the rudders in travel position.
Sail with your mainsheet in hand or draped over the throttle so you can keep your heel right at 15 degrees. Best way to maintain maximum speed.
An admiral helmsman is cheaper than an autopilot. Well, not cheaper, but already priced in.
Ormonddude
Post by Ormonddude »
Mobile home axles are a almost perfect fit for the old steel Mac trailers and you can usually get axle rims and good tires for around $100
Your engine will run longer if the fuel tank is connected to it.
Always have the radio on to the CG channel when on the water. :)
Matt19020 wrote:Getting the boat ready to put it in this weekend and I noticed the ballast drain gate valve was pretty stiff to operate...I put a little white lithium grease on the rod and the gate and the seal...works better then new!
mastreb wrote:An admiral helmsman is cheaper than an autopilot. Well, not cheaper, but already priced in.
But removing it is cost-prohibitive, and usually you end up getting rid of both together. :cry:
reastmure
Post by reastmure »
Stick a couple of velcro tabs (hook side) onto the console and stick your main sheet to it. Then it is always right at your finger tips when you need it.
Steve K
Sailboat: MacGregor 26D
Post by Steve K »
Go sailing :!:
instead of Knots Berry Farm on middle school graduation day :!:
And they give you NO clue until the 50 busses of urchins show up.
If you're wondering.... it was yesterday......... could happen again though :?
Just go sailing all of June :wink:
Best Breezes,
Steve K.
EZ
Location: 2004 26M "Stray Monkey", with Etec 50, SF Bay, CA
Post by EZ »
Use evinrude marine grease for the gate valve instead. I have been told it is more resistant to being washed away.
