Cockpit floor weight limit
grnwtrcruzn
Location: Olympia, WA 1996 X " 20 Knts to Freedom" 1992 90Hp Nissan
Post by grnwtrcruzn »
Hi all,
I've been through all the info I could find about the weight limit on the :macx: cockpit floor but haven't been able to find anything so I thought I'd turn to the experts :wink: . I'm planning on heading out with a couple of buddies next weekend who are on the larger size one's 6'2" and about 225 lbs the other is 6'6" and ~400lbs and then there's me at 160lbs. So all together where close to 800lbs. This got me thinking about what kind of weight that cockpit floor might be able to hold. Anyone have any thoughts on this?
JohnCFI
Re: Cockpit floor weight limit
Post by JohnCFI »
I'm about 230Lbs, and the floor holds me up OK. I would have thought you would be fine....
grnwtrcruzn
JohnCFI wrote:I'm about 230Lbs, and the floor holds me up OK. I would have thought you would be fine....
That's good to hear! Thanks for the reply
I would think the cockpit will be fine. However, that's a lot of weight and you will need to balance everyone. Good counterweight in a heavy wind, just be fast to move during tacks.
Paulieb
Post by Paulieb »
I am 6' 4" 370Lbs - never had any issues...
I've had my Mac for 5 years.
Paiulieb
I'm 6'5", 260 lbs., and I've got sailing with a guy whose 420 lbs., as well as 1500 lbs. of human ballast total (more than anyone should). There's nothing to worry about in terms of structural integrity, but I wouldn't let those big guys go topside and grab the mast on a serious heel.
Matt
If the boat is designed to hold six adults, which it is, then you should not have any problems with three Titans. With the weight that is. :D Fitting comfortably might be an insurmountable challenge :)
Wow, we have some big sailors here. Lucky for me I don't have to reveal my 5'-11" and 225 lb stature. Phew! :P
grnwtrcruzn
Re:
NiceAft wrote:If the boat is designed to hold six adults, which it is, then you should not have any problems with three Titans. With the weight that is. :D Fitting comfortably might be an insurmountable challenge :)
We'll just need to add a couple of 100 lbs ladies to help balance the load and make the cramped conditions more bearable :wink:
I resemble that remark....
JohnCFI
Post by JohnCFI »
I'm just short for my weight! 8)
Gazmn
Post by Gazmn »
When I have >4 aboard, or roughly >650 lbs, I keep the water ballest in even, when not sailing.
I think there is a factory recommendation also to that effect.
I also forbid transiting to the bow topside if we've got more than 4 people aboard. Down through the cabin and up through the hatch if you want to go forward. That's also our rule for anyone under 14. Only person who gets to pull the boat over in an emergency is me.
Matt
grnwtrcruzn
... so it went off without a hitch. 4 of us total pushing a bit over 1k lbs :| cruising around for a day. I was amazed at how the :macx: handled.... the same; the boat always surprises me 8)
Johnacuda
Post by Johnacuda »
Wow, I'm 5' 4" and 160. Single-handing, I am starting to understand some of the variables that help my BF50 pop my :macx: up on a plane so easily.
