My Suzuki 70 tilts all the way up. It barely comes out of the water with full ballast in, but it does.yukonbob wrote:Can't do a full tilt up with a 70 either.
I have the same problem...annoying!yukonbob wrote:Can't do a full tilt up with a 70 either.
Like Mastreb I remain very happy with the Etec 60. We put over 100 hr on it each year. We switched to the 100% synthetic oil after a year or two in order to minimize the smell of oil in the exhaust (although it was never annoying): always starts nicely and runs dependably, VERY little oil consumption at low revs, quiet at low revs, achieves a speed close to 20 mph loaded. We did have it serviced at 3 years ($600) as I am fairly obsessive and not a mechanic. If I could magically convert it to a 75 HP with the wave of a wand, I wouldn't bother; but then we don't water ski. If I could magically convert it to a 4-stroke while keeping all the good things about the Etec for a 26M, then I would - but only to reassure myself that I was getting as quiet an engine as possible.Steve-Deb wrote:Ok, it's a few years down the road from the last post on this topic and motors have developed since. Is everyone still happy with the ETEC 60 only option because I'd like to run a 75hp motor on a late 2014, 26M.
The ETEC is mechanically much simpler than a 4S but electronically more complex. Which basically means that if it actually breaks in some way more than just a fouled sensor, bad impeller, spun hub, or bad electrical contact, you're not going to be fixing it yourself. That said, all the trons are simple part swaps and can be diagnosed quickly at the dealer and repaired inexpensively compared to mechanical wear or damage. The mechanical simplicity should result in longer overall lifetime and lower maintenance, which is what we've been seeing.yukonbob wrote:The 4S is nice not having to worry about oil, it is heavier, but I get asked a half dozen times a year if i'm going to start the engine when it already been going for the last ten minutes. Trolling can be controlled in almost half knot increments from 1.5-4knts. I do like the power to weight ratio of the 2S and the ability to fix almost anywhere with minimal tools (although I believe the Etec is more complicated than a traditional 2S but much more fuel efficient?)
Weird. I bought my boat from BWY and it looks like they installed a plastic wedge behind the motor mounts.yukonbob wrote:Mine Suz 70 doesn't. It hits the captains seat. Barely comes out of the water but is a couple inches below max when it hits, cowlings got some good rub marks. This is well documented by BWY.
