installing new front windows
aikensc
Re: installing new front windows
Post by aikensc »
thanks to all for the advice! I'll see about getting the tape and the correct caulk. i was going to use the wrong one, the 3m 5200 fast set. Jim
Steve K
Sailboat: MacGregor 26D
Post by Steve K »
Dimitri-2000X-Tampa wrote:Yea, if mine was in newish condition, I might consider a cover too...but seeing as its already been in the sun for 14 years and has oxidized gelcoat, etc...why bother 8) I suppose if I ever wanted to invest in restoring the finish (not sure I can bring it back to new condition though), then a cover might be worth it .. but it would need to be somewhat customized to the boat and be able to be put on and taken off rather quickly seeing as there is already so much else to do to get the boat ready.
Dimitri,
Mine is old (25 years)
At this point it's more about avoiding total dry rot than just trying to save the gelcoat. Everything here dry rots. I even have to lubricate all locks on the house and gates, about twice a year, or else you can't get the key in them, they get so dry.
All the southern exposure trim on my house has to be re-stained every year.
Yep, this Mojave desert is rough. I'm sure you've heard of "Death Valley"?? ................. same desert :wink:
So, hopefully, if I get this cover, the boat will last as long as I need it (until I'm dead) to. But as it is now, she'll surely be gone in another 5 years and I plan to last a little longer :wink:
Best Breezes,
Steve K.
