JohnWood wrote:The guy we bought the boat from must have been the nicest man in the world. He cooked a big pot of shrimp creole which was awesome, and then he help us quite a bit to get going. He even offered to let us spend the night. His wife was equally hospitable. You can't substitute for southern hospitality. I've never been deep down in the southern Bayou before, but I may return some day.
I've been to that part of the country and agree, those are some of the nicest folks around.
Interesting problem with your trailer lights. I had a 2004 Sienna AWD SE. Sounds like the same car. Had the hitch and wiring installed at U-Haul and it worked perfectly with my LED wiring on my boat. There was no converter box that I knew of. The wiring went directly into the harness somehow.
BTW, the AWD Sienna has no spare tire. It uses run flat tires instead. I burned up 2 sets of those in less than 25k miles. The first set was replaced by Toyota for free as a recall. Truth seems to be that the run flats are softer rubber on the treads or something and just don't last. After researching others with similar experiences, I decided against another set at $250 each and put standard tires on the car. Softer sidewalls made for a smoother ride. 2 cans of fix a flat, a AAA card and crossed fingers got me by. BTW, the low tire pressure light on the dash is not really measuring tire pressure but revolutions of the wheels. If one is turning less, it assumes you have an inflation problem. Rotating tires sometimes trips this logic up.
(side note on U-Haul: I had them install a hitch on my Highlander. Got home and found lots of weird parts in the backseat so I looked underneath and found they snapped a bolt off one of the attachment points and left it that way. This really scared me. I replace the bolt and should have given them junk about the crappy job they did.)
I will tell you that the first time I towed with it, we just turned onto the Interstate when a light on the dash came on. VSC and ABS lights came on. The car was driving fine, but I pulled off the next exit to investigate. After putting the shift in park, it got stuck in park. Oh great, now we can't even move the rig. Admiral looked up the VSC light in the manual which stated "Bring your vehicle to an authorized dealer immediately." No help there. So as I was searching for the AAA phone number and wondering how much they would charge to tow the van AND boat, the admiral found something in the manual about emergency park release. If you pop this little plastic cover off the shifter and press this button, it came out of park. Woot, we can drive again and headed back home via back roads to sort it out.
At home I found a blown fuse. Could it be that simple? So we tried again for the lake. This time we go 60 miles down the road and made another turn and the lights came back on. I sure wasn't going to put it in park. We got to the marina and I found the fuse blown again. Replaced and VSC warning light went out. What was blowing fuses and how much is this gonna cost to fix at the dealer? Surely they will blame it on towing a boat without the official "Toyota towing package" which is just a tranny cooler.
The trailer lights were old and beat up so I decided to replace them with LEDs and a new harness. Pulling the old harness out revealed the issue. The wires were worn and frayed and had rubbed against the trailer and when I would make a turn shorting them out and BLOWING THE FUSE in the van.
So what I learned was Toyota wires the brake lights to the same fuse used for VSC and ABS computers. Toyota engineers feel that when these systems are not functioning, you shouldn't be driving and lock your gear shifter in park when you shift it into park.
Keep this in mind when trailering with that van and keep some spare fuses. I think there are some spares on the cover. The brake light (and VSC) fuse is at the base of the steering column and one of those micro blade fuses.
Probably too late, but you shouldn't operate that van with Overdrive on. I can't remember if there is a button to turn it off or just a shifter position. I never used cruise control. Just freaked me out when it started downshifing and revving up on its own.
That is a great boat and you will love it. These boats are easy to work on.
If you want a resource for mods, Sumner has done a fantastic job of documenting all of his here
http://purplesagetradingpost.com/sumner ... index.html
I have used his site and mods many times for reference and information. I also bought the 12v fridge he has. Works great.
Now go enjoy sailing!
