wheel tamer
Wayne nicol
Re: wheel tamer
sound advice mastreb, i will be doing that, i was thinking about using that "never sieze" goop, but i seem to remember something about it and salt water- am i right or wrong here?- maybe just use grease
- u12fly
Re: wheel tamer
Hmmm, I took my wheel off a few years ago. Yes it took more than five minuets
But I guess I should have used some anti seize on re-assembly
DaveC426913
Re: wheel tamer
S'OK. There's more thna one way to skin this Mac. I can get at the pedestal another way.
My design failed. Ultimately, the confounding fact is that and arm long enough to reach the wheel rim is too long to lie flat against the pedestal.
Back to the drawing board.
drams_1999
Re: wheel tamer
Ron, I like what you did with the DIY adjustable friction wheel brake, do you have any pictures?
Re: wheel tamer
+1J-- wrote:Maybe I'm under thinking this, but wouldn't just a bungie cord work?
http://www.macgregorsailors.com/modt/in ... ?view=1401
DaveC426913
Re: wheel tamer
Historically, I have had a tendency to leap from the helm to attend to something or other, esp. when single-handing. eg. an accidental tack, or docking. Additionally, I need to disengage the tamer from forward of the helm, and usually with one hand.J-- wrote:Maybe I'm under thinking this, but wouldn't just a bungie cord work?
So I'm looking for something that I can reach from anywhere and set/unset with just a flip. Imagine being forward of the helm, manning a jib sheet around a winch, and trying to reach under the aft-side of the helm for two dangling ends of that bungie, and putting them on the wheel. Not a chance.
(That being said, I'm finding my sailing style changing. A big help is my EZ cleats, mounted right on the tracks. My jib sheets are manageable right from the helm. I spend a lot less time rushing around the boat.)
- Max Entropy
- Location: Saanich, British Columbia, 2008 26M 70hp Suzuki
Re: wheel tamer
That's a good refinementTomfoolery wrote:
Or adapt a bicycle disk brake to the backside of the wheel, mounted to the spokes and spaced far enough back to fit a caliper, if there's enough room.
Nick
Re: wheel tamer
You didn't specify if your interest in a "wheel tamer" is under sail or under power. If under sail, I have learned to balance the sails and the boat (2000 26X) will hold course for several minutes without correction, allowing me to go below briefly. If under power, I just put the engine in neutral and let the boat drift while I go below.
Bill
Bill
DaveC426913
Re: wheel tamer
Lordy-lord, I won't even take ONE hand off the wheel when motoring, for fear of doing a triple-lutz and finishing with keel-to-sky!wcole wrote:You didn't specify if your interest in a "wheel tamer" is under sail or under power.
Yes. My need for the wheel tamer is when my sails are NOT balanced, because I need to run forward to free a caught sheet or furler line while halfway through a tack, or some other such thing.wcole wrote:If under sail, I have learned to balance the sails and the boat (2000 26X) will hold course for several minutes without correction, allowing me to go below briefly.
Re: wheel tamer
The best wheel tamer is A/P
under power
http://s844.photobucket.com/user/TheHig ... 2.mp4.html
or under sail
http://s844.photobucket.com/user/TheHig ... 0.mp4.html
or under sail
Re: wheel tamer
When I have a problem with the boat that requires attention, hoving to settles things down quickly. The boat drifts about 2 knots to leeward very sedately even in 25 knot breezes.
Bill
Bill
