I've read that these hulls are thin,and now that I have one I understand...they are very thin. I'm interested to know how much deck flexing is normal when pulling moderately hard on the pilots and stations. Mine gives a several millimeters at least...feel like if I fell over and grabbed one of the stations that it might just break the deck. Alas I dont want to see how strong they are, just know what strong enough is.
The liner is also quite thin, and while stepping into the cabin onto the keel channel I can hear it sort of crackle like its breaking a little bit more every time I step on it. Not like its going to break, but enough to wonder how many hundred times its going to handle it before that slight crackle becomes an issue. The same occurs when steeping on different parts of the cockpit and on deck if I put too much weight on one of my knees while crawling around up there scrubbing it. Perhaps I'm just used to larger boats with much thicker layups that don't give and flex at all when moving around on them.
Two of my shrouds have one or two broken strands. It doesn't appear as though they broke from stress, but like something may have impacted it at some point. Should I replace them, or is it a big deal to have a couple broken strands?
I haven't dropped the keel, but looking up into the pocket, its very clean and appears damage free aside from the keel feeling like its got a bit too much play in it. How much play is normal on the keel?
I'm surely gonna have a million more questions for you guys, so I've gotta say. Thanks in advance.
