Swap Meet!
- mastreb
Swap Meet!
This thread is for posting MacGregor-related objects that you intend to give away. Rules are:
1) You do not charge for the object.
2) You can charge for shipping, but the shipping value must be backed up by a shipping receipt from a national postal service or a global shipping brand recognized by anyone who might challenge the cost. The intent here is not to compete with the ad service provided by this board.
3) Post a reply describing the item.
4) QUOTE THE ITEM if you want it.
5) EDIT THE ORIGINAL POST and change to "SOLD" when your item is no longer available.
6) Scroll through all the otherwise empty SOLD posts to find things still available.
7) It would be bad form to take an object here and then resell it. Nobody will check, but your personal deity will hold it against you in the hereafter.
Give it away now!
Give it away now!
- mastreb
Re: Swap Meet!
SOLD: Windex
- mastreb
Re: Swap Meet!
SOLD: Bent mast, stripped of parts. Bend is at the spreaders.
- mastreb
Re: Swap Meet!
MacGregor stock Mainsail, torn at the headboard about three inches. Not blown out, otherwise in excellent condition.
- mastreb
Re: Swap Meet!
SOLD--New trailer winch + 25' aircraft stainless cable and hook. Decided not to implement.
- yukonbob
Re: Swap Meet!
Back rest cushions for
Back rest for
(Rigid one on starboard side in front of stock cooler location)
Single burner butane stove missing grill hardly used
BWY genoa track ladder -SOLD
Stock Doyle jib -SOLD
Stock Doyle Main -SOLD
Back rest for
Re: Swap Meet!
I have the white cockpit cushions for the X captains seat, 1 bottom and 1 back piece. Should fit in a large flat rate box.
Re: Swap Meet!
I could use a new winch. Mine broke Labor Day weekend.mastreb wrote:New trailer winch + 25' aircraft stainless cable and hook. Decided not to implement.
No Control
Re: Swap Meet!
I could use a main and a jib for myyukonbob wrote:Back rest cushions for![]()
Back rest for![]()
Stock Doyle jib
Stock Doyle Main
What condition?
Please let me know what shipping will be to 48161.
Thanks!
- Steve K
- Sailboat: MacGregor 26D
Re: Swap Meet!
Hey Matt,
I forget..... was that mast the same cross section as the X and D? If so, would you want to get rid of a couple feet at a time?
Best Breezes,
Steve K.
Best Breezes,
Steve K.
- March
Re: Swap Meet!
No control:
I would be interested in the genoa track ladder--if the shipping is not prohibitively expensive to Iowa?
Thank you
Thank you
- yukonbob
Re: Swap Meet!
That would be me. PM me and I'll try and figure out shipping.March wrote:No control:
Thank you
- yukonbob
Re: Swap Meet!
Also just to clarify, the sails are for an M. If anyone knows if they will work on an X (had interest) this would save someone the headache of it not working out.
- yukonbob
Re: Swap Meet!
Ok gonna post some shipping here as I'm finding it hard to manage PM's.
Four people want the jib last on the list is the only M I know it will work for. Ground shipping is around $60 (lower States) based on a 24" x 24" x 4" 20lb package
Two people want the Main both are X's not sure if it will work. I imagine based on similar size shipping will be about the same.
Ladder is gone.
Ladder is gone.
