Another guy on the Mac owners forum had a strike to his boat this summer sitting on the hard with the mast up. No grounding to the mast and it still got struck.
yep.. a lot of theory here especially when water is involved - which really cant be proved. Dimitri, your event is very interesting and significant. This would go into a bunch more theory but these guys studied actual lightning rods on a mountain top for a bunch of years and had some interesting results that actually may backup what you are currently doing.
http://analogengineering.com/lightning/ ... tudy_1.pdf
One more thing about grounding since it is often said (on this forum) that you have to spend a lot of money to do it right - or don’t bother.
A side flash occurs when lightning enters some conductor such as a mast but then turns back into lightning on its path to ground. The problem with a side flash is that it’s very unpredictable. In a grounded "facility", you want to control where the current goes so you want to keep it in the conductors that you planned. But if you don’t bond and observe bend radius guidelines, you might have an unpredictable side flash. In the sailboat, this side flash would come off the bottom of the mast or shrouds/chainplates and if people are on the boat, it could be dangerous.
So with a building, you bond perfectly to get close to zero percent chance of a side flash.. Now if start to cut corners on bonding, the chances of a side flash start to increase. Or as has already been noted, if you don’t spend the money to bond well, you start to invite a side flash.
All of our water ballast boats are similar in that they have no bonding at all. I have an old S model but the M, D,S are all very similar and the X is significantly similar.
In our boats with no grounding or bonding at all, you start off with a 100% chance of a side flash. If lighting strikes the mast, it has no where to go but to turn back into lightning to get to ground. We noted that side flashes are bad since they are so unpredictable - yet we start of with a 100% chance of them happening.
However, as we add any sort of grounding (such as Dimitri did), we don’t reduce the chances of a side flash to zero - but we do REDUCE the odd's of a side flash. So any sort of grounding or bonding when you start out with 100% chance actually reduces your chances of side flash. The word "invite" would say you are increasing your odds but that is not the case, you are actually decreasing since you start off with the very worst possible configuration.
Now as you add and improve the bonding to the sailboat, the odds of the side flash continue to DECREASE. The idea that you have to spend a lot of money to do this correct has some merit - if your goal is to decrease the odds all the way down near zero. The point being that on the ungrounded water ballast trailer boat, since we start off with a grounding situation that is as bad as it can get, adding any grounding actually reduces the chances of a side flash.
One note for Dimitri that is a little far fetched.. but if you look at the paper I posted that has actual results (plus some theory - those PHD guys can’t help themselves), they had a bunch of sharp lighting rods and a bunch of blunt lighting rods spaced so as to not favor any type. All were grounded. In a bunch of years, the blunt lighting rods got struck numerous times but the sharp lighting rods did not get struck at all. That looks statistically significant to me..
I almost hate to say this since its some of the crazy theory stuff that I usually have a "problem" with but the very sharp tipped Franklin lightning rods were the ones that never took a strike. Maybe put a very sharp tip at the top of your grounded mast... Why not...
This is grounding.. and I still trying to understand the "avoidance" theory for a sailboat on water that is somehow based on a few words in some business's video describing how the rolling sphere method works.
