http://www.westmarine.com/WestAdvisor/T ... Conditions4. No “Green Wire” or poor-quality connection between DC negative and AC safety ground.
Without a good connection between DC negative and AC safety ground, stray AC current may enter the DC ground system. When this happens, AC current may enter the water around a boat and injure or kill swimmers near the boat. The green wire is the safety ground wire that connects the DC negative ground block to the AC safety ground bus. The purpose of this wire is to provide a lowest-resistance path to ground for any stray AC current that finds its way onto the DC ground system. There have been cases of AC current entering the water around a boat through the engine shaft and killing swimmers near the boat. For more on how to prevent this, see our West Advisor on ELCI/GFCI Electrical Shock
Read the 3 links I posted.
You have the hot and ground side on both the AC and DC circuits and on the AC the neutral white also. You can't assume that the wiring at the marina is correct and something isn't reversed in their wiring which is the reason for the polarity checker. If their wiring gets reversed then you can get AC into the ground side of your DC circuit on the boat and then into the water.
If your boat is in the water please do it right. If you took the charger out of the equation and only took AC on board with a cord that went only to outlets and couldn't get to the DC circuits in the boat (the charger) then things wouldn't be quite as bad.
On the inverter issue we have used...
http://www.amazon.com/Wagan-EL2200-Elit ... 210&sr=8-2
...the pure sine wave inverter above with good luck....
.... running chargers and such. It isn't huge but has worked for us.
... the
