The Navionics iPhone app is cheaper and it will run on both so you can try it first. I have a cheap waterproof case that has a loop for a lanyard.
http://www.aliexpress.com/item/Selljims ... 92546.html
Favorite Smart Phone Apps?
- tewharaunz
Re: Favorite Smart Phone Apps?
You can tether it to a phone, or just use the Navionics like a chart.Neo wrote:Thanks Guys,
I've downloaded most of these on my iPad. With regards to Navionics, it's available in HD for the iPad .... Is HD worth the extra expense?
UPDATE!
Bugger!.... Just remembered that my iPad does not have 3G/4G or GPS support ... so pretty useless!! ... Will have to spend more dollars!!
Also what do you iPad users use as case/enclosure for your iPad?
All the best.
Neo
I use mine under the enclosure in bad weather or up top in good. No case.
I use the LIFEPROOF NUUD waterproof case for my IPAD AIR 2. There is also a LIFEPROOF FRE' case for older IPADs.
- Neo
Yes, but I don't know of a way to Tether to a GPS receiver, so to speakCatigale wrote:You can tether it to a phone, or just use the Navionics like a chart.
- Neo
Thanks again Kadetkadet wrote:FYI Neo
https://www.whitworths.com.au/main_item ... lutePage=1
danc1957
I believe there are Bluetooth GPS pucks on the market that should be able to interface with an IPad, haven't seen one in awhile though...Neo wrote:Yes, but I don't know of a way to Tether to a GPS receiver, so to speakCatigale wrote:You can tether it to a phone, or just use the Navionics like a chart.
Found one here:
http://bad-elf.com/pages/be-gps-2200-detail
