Smartphone Wind Velocity Meters
Berber Boy
Location: Paynesville, VIC 3880 AUSTRALIA WindSong 2016 26M 75hp Etec
Post by Berber Boy »
Has anyone tried out the Ronstan Vaavud V2 Wind meter yet. Seems a cheap option to get reasonably accurate wind measurement although not at the top of the mast.
http://www.ronstan.com.au/marine5/Vaavud.asp
BB
Re: Smartphone Wind Velocity Meters
I saw them in WM, but for the price of a dedicated hand-held instrument, I thought it wasn't worth it. And the egg cups look like they're susceptible to breakage, especially the way I treat the contents of my boat. The other style, with the impeller in a housing, would be less likely to get damaged, too. Either a dedicated instrument, or a plug-in for a smart phone.
Never used one of the smart phone gadgets. I have one of these and it works well when curious about speed.
Obelix
Post by Obelix »
We're using a dedicated hand-held as well. Th sensitivity of the turbine-wheel is making it easier to get the wind direction as well.
Obelix
Berber Boy
Tomfoolery wrote:I saw them in WM, but for the price of a dedicated hand-held instrument, I thought it wasn't worth it. And the egg cups look like they're susceptible to breakage, especially the way I treat the contents of my boat. The other style, with the impeller in a housing, would be less likely to get damaged, too. Either a dedicated instrument, or a plug-in for a smart phone.
That is my thinking too. I have a dedicated Celeston that has stood up and performed well for at least 7 years and the cups do loo9k susceptible to breakage although V2 looks a better redesign
BB
I have the original Vavuud before Ronstan bought them. They work well. There's no electronics to it; the shaft has two magnets on it which rotate, causing the microphone voice coil to move in and out. This creates a sinewave that the phone picks up as sound, and the app converts the frequency of the sound to windspeed.
It's incredibly simple. Mine hasn't broken, but it does seem a bit fragile. Because it's cup-based, you cannot turn it to get the wind direction the way you can with the fan units.
