Winches
Flightfollowing
Re: Winches
There are also ez-cleats to achieve similar results to go on the tracks if you don't want to move/install winches.
- BOAT
Re: Winches
EZ Cleats I have, but with the Genoa in a good blow I sure would like some winches back there - that's really where the genoa winches belong anyways. They should be on each side of the cockpit, not on top of the cabin. Winches on top of the cabin are only for a jib, not a genoa. It's the wrong place for the winch.Flightfollowing wrote:There are also ez-cleats to achieve similar results to go on the tracks if you don't want to move/install winches.
I wish the factory had put the winches in the right spot.
Re: Winches
If you can't sheet the Genny in by hand you have too much sail out anyhow, but winches in back is a nice mod for single handing.
bdailjr
Re: Winches
Where can you obtain the EZ cleat for the gen track? Have been looking, but have not found them. Assistance greatly appreciated.
- NiceAft
Re: Winches
Contact Bill at http://www.boats4sail.info or google Bill's EZCleats.
I use them for my genny exclusively.
- dlandersson
Re: Winches
Ditto
NiceAft wrote:Contact Bill at http://www.boats4sail.info or google Bill's EZCleats.
