My X-type sailing rig was destroyed when I hit a piling.
So I replaced the X-rig with a M-rig. Gateway Sailing in Punta Gorda, FL did the work. Basically they had to put a new mast step in and new chainplates set about 8 inches more to the rear than the normal X-rig.
I took it out for a sail yesterday in about 15 to 20 mph wind. It works great. I did not take GPS measurements but it seems faster on all points of sail. It also goes about 5 maybe 10 degrees closer to the wind.
The rotating mast really does improve things. It got caught at the wrong angle, I manually adjusted it to the wind and we took off at least another knot or so. The boat does not seem to lean anymore than it used to, it just goes better.
