26X centerboard repair
Albertagirl
Our centerboard has split open at the seam along the bottom. It is a 1998 26X. We think water must have frozen inside, and the bottom crack is open about 3/4 inch where it was bonded together. Has anyone repaired this problem?
- DaveB
Re: 26X centerboard repair
My centerboard 1997x had cracks on the head and lower end. I fiber glassed it and gelcoat . I have lot of experience in repairing fiberglass.
If you don't I would get a replacement tru BYW.
These centerboards and rudders thru these early years are known for weak fiberglass connections and will crack at seam and in cold freeze will split the seam if water is inside, even in warm waters it still splits.
Albertagirl wrote:Our centerboard has split open at the seam along the bottom. It is a 1998 26X. We think water must have frozen inside, and the bottom crack is open about 3/4 inch where it was bonded together. Has anyone repaired this problem?
Billy
If you think you might need to replace the cb, you can order it from Ruddercraft. Joel has the original Mac molds for the centerboard and rudders. I got an extra set for my X a while back, just in case.
I then repaired my damaged cb and reinstalled it. It's just fiberglass. Go for it. If you have never worked with fiberglass, it's a good place to start. Besides no one will be able to see it. You can only make it stronger. Best of luck!
