What I did this past weekend was the following:
- pull up to around 6 ft depth (stern facing the shore)
- drop anchor, raise motor and let the anchor line out until depth was 3 ft at the stern
- use both aft docking lines and a pair of 48" long earth augers in the water to pin the rear facing the shore (rather than left the boat drift around the anchor).
This worked well except it needed three people (one at the wheel, one at the bow letting out anchor line, one in the water to hold the aft docking line) and we also ran out of anchor line before getting the boat as close to shore as we would have liked....
The next time I'm going to try the following:
- get close to shore (3-4ft depth as measured from the stern) but with bow pointing towards shore (bow depth is shallower that way)
- one person stay at wheel, but shut off and raise motor to clear water
- second person jump in the water, grab the bow docking line
- let the boat naturally pivot around the bow until stern is facing shore (or close to it)
- pin the boat using bow docking line and 2 stern docking lines with 3 earth augers, and do not use the anchor at all.
Dunno how well that pivot maneuver will work but I did find it pretty easy to manipulate the boat standing in the water (even with the ballast full)
Any other ideas? Also, does anyone actually beach the bow of the boat? My concern (other than getting trapped on shore
